Displays the contents of the IPv6 routing table for routes with the specified origin.
| direct | Specifies direct routes. |
| auto-peering | Specifies BGP auto-peering routes. |
| static | Specifies static routes. |
| blackhole | Specifies blackhole routes. |
| ripng | Specifies RIPng routes. |
| ospfv3 | Specifies OSPFv3 routes. |
| ospfv3-intra | Specifies OSPFv3 Intra routing. |
| ospfv3-inter | Specifies OSPFv3 Inter routing. |
| ospfv3-extern1 | Specifies OSPFv3 External 1 routing. |
| ospfv3-extern2 | Specifies OSPFv3 External 2 routing. |
| isis | Specifies IS-IS routes. |
| isis-level-1 | Specifies IS-IS Level 1 routing. |
| isis-level-2 | Specifies IS-IS Level 2 routing. |
| isis-level-1-external | Specifies IS-IS Level 1 External routing. |
| isis-level-2-external | Specifies IS-IS Level 2 External routing. |
| bgp | Specifies Border Gateway Protocol. |
| ibgp | Specifies Interior BGP route. |
| ebgp | Specifies Exterior BGP route. |
| bootp | Specifies BOOTP route. |
| host-mobility | Specifies host-mobility routes. |
| vr_name | Specifies a VR or VRF. |
N/A.
None.
The following example displays the RIPng routes:
show iproute ipv6 origin ripng
The bootp attribute was added in 15.7.1
The auto-peering option was added in ExtremeXOS 22.5.
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
